smtp with Office 365
  • thinkink
    • Apr 2016
    • 62
    We have a customer with 1- CS-308ci and 2-CS-406ci. Outgoing email is set up using an office 365 account. The 308ci is working fine but the 406ci are only intermittently. I feel it is an office365 security issue, but was wondering if anyone else has found the same experience.
  • Konicatech
    • Feb 2016
    • 131
    Re: smtp with Office 365
    Hi
    Update firmware to latest version and then log in via the Command Centre > Security Settings and make sure that the following are ticked and then restart the device and try a scan:
    Serverside settings - make sure TLS 1.1 and TLS 1.2 are checked
    Hash - Make sure SHA1 and SHA2 are checked
    Clientside Settings - Make sure TLS 1.1 and TLS 1.2 are checked
    • thinkink
      • Apr 2016
      • 62
      Originally posted by Konicatech
      Hi
      I should have made myself clear here. This is for outgoing email settings using smtp.office356.com as smtp server.
      • darry1322
        • Oct 2010
        • 817
        The answer remains the same. This is to update the security settings for connecting to a 365 smtp server.
        • thinkink
          • Apr 2016
          • 62
          thank you!
          • sparkycivic
            • Apr 2017
            • 348
            It's my understanding that ONLY TLS 1.2 can be enabled plus all available hashes, and all lesser TLS and SSL must be disabled in order to have success with Office 365.
            • J_Arnold
              IT Director
              • Sep 2021
              • 87
              Are you sharing the email FROM address? 365 has an issue with this sometimes, something about 2 IPs using the same address flags something internally causing it to send the email into quarantine (Gray listing). This can usually be addressed and fixed in the o-365 admin panel. It will hold email for a period and then release sometimes as well, this might explain the intermittent working. Could be sending certain scans to Junk email (doubtful) but worth checking to be thorough, if so just allow to trusted sender list.
              “First comes smiles, then lies. Last is gunfire."
              • peterthebest
                • Mar 2013
                • 5
                Allo every one ,
                Is there any of this solution that worked.
                I have a similar problem. Ta-3253ci scans well with office 365 and in the same office, 4 m2040dn with the same configuration does not scan in o365.
                Thank you !
                • Konicatech
                  • Feb 2016
                  • 131
                  Allo every one ,
                  Thank you !
                  Hi
                  I already gave the solution.. You must update the firmware on the device to the latest version and you must enable the correct TLS Settings.
                  • Samanator
                    • Sep 2017
                    • 579
                    Be sure to update you device to the latest Kyocera firmware then follow the attached from Kyocera. It also says to update the firmware.
                    • kuby
                      • Oct 2007
                      • 1408
                      Microsoft changed security setting a little while back.
                      See if this helps.
