Ecosys M5526 stripes after removing jammed paper
  • i-have-no-clue
    • Feb 2014
    • 14
    After simply removing a jammed paper at the rear side the MFP has this problem
    This is a print of the status page. Same problem when you make a color copy.
    There seems to be no problem when you make a black and white copy.
    What has happened. Is a electronic board or high voltage unit broken?
    Who knows this problem.
    I fear I don't like these Kyocera machines -
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: Ecosys M5526 stripes after removing jammed paper
    You could start by reseating all the drums and developers but after that I'd order a PM kit because you have a voltage leak from one of the dev units.
      • 22999
      One of the developing units is arcing to it's drum. When it does, the HVT shuts down for a fraction of a second, making one crossfeed bar of each yellow/cyan/magenta/black. When it happens repeatedly, the bars start to overlap producing interest color bands. The trick is determine which of these developing units is arcing. As you look at your samples, the color with the faintest bars is usually the one that's arcing out. And you'll want to change the affected drum and developing unit at the same time.
      So depending on your skill/luck, this could take 1 visit ... up to 4 visits to get the right combination, or you could shotgun it and order all four color developers and four drums. It's up to you. =^..^=
