taskalfa 5501i cassete
  • Gab
    • Aug 2015
    • 671
    Message "can not use cassete 1 due to a failure " appears. Can i reset it?
    How can i check what the problem is?
  • ntbann
    • Jan 2012
    • 628
    Re: taskalfa 5501i cassete
    906
      • 30310
      Reset in service mode
      • JVergin
        Service Tech / IT Rep
        • 216
        Make sure there's no paper stuck behind the tray. Then U906 to reset.
        • spw
          • Mar 2015
          • 62
          Unless it was a user induced cassette error it will come back after the 906 after a while. Its best to test the lift motor while there after the reset to make sure it has the the strength to lift various paper loads while running.
          • sparkycivic
            • Apr 2017
            • 348
            print the error log, and find out when and what the tray coded. probably had paper stuck behind the cassette at some point...
