The machine sometimes prints as in the example, the drum unit was tested. can you help?
fs-1135 missing print problem
This gallery has 1 photos.Tags: None -
Take a look at the developing roller. My guess is that there isn't any toner coverage at one end or the other. There may be no spring pressure at one end of the transfer roller.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 3 -
