F3D4 on TA-352ci
  • taskalfaman
    • Nov 2009
    • 137
    F3D4 on TA-352ci
    Someone experience and an explanation for the error code F3D4.
    new device and can't find any explanation of the reason/cause for this error.
    Any hint is welcome
  • copiertec
    • Jan 2016
    • 2187
    Re: F3D4 on TA-352ci
    When do you get the error code? Is it during a print/copy?
      • 22985
      That kinda looks like a Mebius or Mebius2.
      CF3Dx: An error is detected at the Entity management section. 1) Reformat HDD U024 FULL; 2) Initialize backup memory U021; 3) Repl main PWB; 4) Repl HDD; 5) Retrieve USBLOG and contact SAD.
      I'm not sure what all of that means, but I'd probably treat it like every other CFxxx code:
      Firmware
      Investigate Network Issues
      HDD
      Will the device work at all, even momentarily? Will it work off the network? =^..^=
