Taskalfa 2554ci Scan error 4901
  • kyotechnz
    • Mar 2019
    • 150
    Have a customer with a Taskalfa 2554ci getting a scan error 4901 (scan to email).
    Firmware is up to date. The Test Button comes back Connection OK. All the settings as far as I can see are correct.
    The guy at Kyocera I deal with does not know what that error means but hopefully will find out for me.
    Have tried through a Gmail account and their company mail server.
    Has anyone seen this error before?
    • 30421
    Re: Taskalfa 2554ci Scan error 4901
    check the security settings and see if anyone turn off stuff that suppose to be on ie tls settings
      • 16455
      If you sync the time setting by using " time.windows.com", does it work? I always do this to see if I'm actually connected to the internet. I'd rule that out as a possibility at least.
      • Ropariva
        • Mar 2016
        • 693
        You could try again with network settings on DHCP.
        Is it a new installation, IE new customer, or is it replacing an existing Kyocera?
        • kyotechnz
          • Mar 2019
          • 150
          I have heard back from our Kyocera rep and have been told what the 4901 error means.
          It is a "General failure code to validate certificate". Check SMTP Server certificate.
          Getting customer to check the certificates at their end.
          Will check encryption settings and SMTP security settings on copier.
          • AndresM
            • Jan 2016
            • 37
            You can tray setting DNS 8.8.8.8 and 8.8.4.4 for Google server , SMTP.gmail.com.
            Good luck.
            Andy
