Kyocera 3051ci magenta streaks
  • stern.detmold.32756
    • Feb 2018
    • 25
    Hello,
    our Kyocera 3051ci leaves magenta streaks on paper, sometimes on the front, but sometimes also on the flipside.
    The drum cleaning program sometimes(?) fixes the issue for 2-3 pages, then it comes back. The other cleaning programs do not effect the outcome.
    The streaks are also not on the exact same position every print, black and white prints usually come out fine.
    We cleaned the insides, there was loose magenta toner on the transfer belt.
    The toner on the pages is dry and can not be rubbed off.
    I tried the one spare magenta toner we had, but it did not accept the toner. (We sadly do not use genuine toner)
    Thanks in advance!
    Re: Kyocera 3051ci magenta streaks
    Originally posted by stern.detmold.32756
    Hello,
    Thanks in advance!
    [ATTACH=CONFIG]51982[/ATTACH]
    Try clean/replace PCR and inspect drum for proper cleaning.
    What is the life count of the machine and supply count?
    • allan
      RTFM!!
      • 5463
      Toner stuck to magenta development roller?
      Whatever
        • 22973
        If there's transfer waste on the primary transfer belt ... perhaps then primary transfer belt is not cleaning correctly?
        • craigster
          • Apr 2016
          • 201
          I usually would replace drum and developer especially with those streaks.
          • avio2
            • Jul 2010
            • 150
            i think cleaning ass'y DRM clogged, check the waste hopper gears
