replacement controler board Kyocera TA 3253Ci
  • levillageinformatique
    • May 2025
    • 18
    Hello everybody,
    anyone know how to configure replacement of controler bord in TA 3253Ci ?
    I can take new controler board in another machine
    Apparently we must initialize a technical mode, (like serial number ?)
    If somenone can help me ???
    Best regards
  • rickirobert
    • Mar 2019
    • 32
    1 Restore backup data on SSD.
    • This has to be done before run U004.
    Execute maintenance mode U026 / Flash / Restore
    2 Restore exported machine settings and job settings by importing with U917 in advance.
    3 Set Machine serial number
    • C0180 error comes up when turn on machine since no serial number so that U004 has to be run to match the
    serial numbers in the PWBs.
    Execute it after confirming the engine PWB machine serial number matches the main unit serial number.
    Wrong data will be written when there is a discrepancy in U004 *1.
    1 Input "004" using the numeric keys and press [Start] key.
    2 Select [Execute] and press [Start] key.
    3 Turn the power switch off then on. Wait more than 5 seconds between the power off and on.
    4 Firmware update (See page page 5-1)
    • Check the latest firmware and upgrade it.
    5 ID correction operation setting (maintenance mode U464): Calib
    1 Input "464" using the numeric keys and press [Start] key.
    2 Select [Calib].
    3 Select [Execute] and press [Start] key.
    • Calibration starts.
    4 Press [Stop] key.
    6 Auto halftone adjustment (maintenance mode U410)
    1 Input "410" using the numeric keys.
    2 Select [Coeciffient].
    3 Select [Initialize] and press the [Start] key.
    • The correction value will be initialized.
    4 Press [Stop] key.
    • Execution information screen is displayed.
    • Test chart 1, 2 and 3 are output on the A4/Letter paper.
    7 Resetting the initial settings
    • Input setting from maintenance report (U000) that output in advance.
    U251: Cassette counter
    U265: Destination setting
    U065: Main Scan adjustment value
    U402: Margin setting value
    Other setting that is changed in setup
    • Registration for net work certification
    • In case of displaying customize screen U224: Home screen install
    • Set interface block function or security level setting from [System Menu] in case that those are changed from
    default.
    • In case of install Security Kit, Input the key code.
    • Set network since MAC address (Printer name) gets changed.
    8 Exiting from the maintenance mode
    Input "001" using the numeric keys and press [Start] key.​
    • ATM
      • Apr 2025
      • 45
      Why do you need to replace it? is it because of damaged ETH port?
      • Ropariva
        • 693
        As above, that’s everything you might want to do, but the minimum you need to do is swap the ssd, install the board. Turn on, you’ll get a C180. Enter service mode, run U004, execute. Reboot. Machine should now be operating. Load firmware to ensure entire machine is at same level.
        if you’ve been able to take a U917 backup, import that and away you go.
          • May 2025
          • 18
          2 Select [Calib].
          4 Press [Stop] key.
          4 Press [Stop] key.
          default.
          Thank you so much !!!
            • May 2025
            • 18
            yes, nothing else to do, complely damaged !!!! regards
              • May 2025
              • 18
              thank you for your answer, regards, now I have changed
              • ATM
                • Apr 2025
                • 45
                There's always optional ETH - IB-50. It's cheaper and faster.
