taskalfa 1801 drum replacement
  • kalaris
    • 70
    Hi
    I replaced a compatible blade drum and charge roller. Reused, copies with gray background. They told me that the chip that I don't have should also be replaced. Is there any way to regulate it?
  • GIUBOSS
    • 1431
    Re: taskalfa 1801 drum replacement
    Try cleaning the magnetic roller with a dry cloth, genuine toner? It can also depend on the drum that took too much light. It happened to me too and it solved itself by working on it.
    • kalaris
      • 70
      Consider that I put the old drum back and the dark bottom does not. Reading a few posts, I saw that the compatible drum needs to replace the chip. I wanted to know if it can be remedied in some other way.
