KYOCERA DP-7110 installed on UTAX
  • Ilario
    • 1
    Hello,
    a friend gave us a spare used DP-7110, it is Kyocera branded and previously installed on a Taskalfa 2552ci, perfectly functioning. We tried to install it on a Utax 2506ci that should be the equivalent machine of the Taskalfa 2552ci but the Utax does not recognize it.
    Do you know if the DP are branded "locked" ? I did replace many DP in the past but this is the first time trying to install a Kyocera branded DP on a Utax.
  • KYO_OEM
    • Aug 2011
    • 720
    "no branded locked" other issue.
    • kuby
      • Oct 2007
      • 1408
      Did you get the boards for the copier installed and seated securely. Had that happen on one that the board for the copier came loose and had to push and snap it back in.
