As our 300ci is BER we're looking at a used 3253ci One machine we thinking about getting showed the following counters (U251) U251: M Cnt A: 17669 M Cnt B: 8626 M Cnt D: 17669 M Cnt E: 8626 M Cnt HT: 17669 Cassette 1: 13123 Cassette 2: 1672 Cassette 3: 501 Cassette 4: 276 As we're not able to find a service manual for the 3253ci and based on the web this means Half Tone corrections?! What could be the reason that M Cnt HT shows the same number as M Cnt A ?
Taskalfa 3253ci U251 M Cnt A equals M Cnt HT = 17669?
Tags: None
MNT count HT shows the last execution from U410/ Halfton Adjustment.
After running successfully this adjustment, count get back to [0] and counting up until next run from U410
if you run the halftone adjustment by systemmenue > adjustment/ maintenance it`s the same.
This count must be less or the same depended to all LLU parts.
If this count is higher than e.g. U110, U127, U158 you know that no needed adjustments would done after replacement from the LLu parts and system is still running with wrong voltages/ data....👍 2
