6500i DP jam error 9008
  • buzz
    • Aug 2013
    • 288
    Originals feed in slow and eventually triggers error 9008 which means the original is not reaching the CIS sensor in time.
    Changed feed belt, sep, and sep limiter so far.
    My guess would be the feed one way bearing with shaft next but wanted to get any feedback first.
    Here's the video, let me know if you've seen something like this:
    Thanks!
  • copiertec
    • Jan 2016
    • 2211
    Re: 6500i DP jam error 9008
    I haven't seen this particular circumstance but replacing the one way bearing and shaft is not a bad idea. Also check to see if the original lift tray is working properly as well, seems like it is in the video.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      I would say you're right on target. I strip them out of parts machines and always carry a rebuilt one with me.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • sparkycivic
        • Apr 2017
        • 348
        you should be able to see with your eyes or a phone camera whether or not the belt is moving with the paper, or with the drive. this will point you toward mechanical drive, or friction/pressure issue.
        the regularity of the movement tells me that a spring pressure, separation torque, or belt friction isn't right.
