TA 4551ci F279 Error when coming out of sleep mode
  • Doug James
    • Jan 2012
    • 935
    [Error Code] TA 4551ci F279 Error when coming out of sleep mode
    Hello, I am refurbing this machine. It works great but when it goes to sleep. I will push the "on" button then it will error out. I formatted hd u024, u021 memory initilize controller backup. Replaced HDD. Did factory reset and reinstalled f/w. I haven't installed a new MPWB yet. Wanted to get any thoughts on this prior. Thanks for any comments.... Can't find much on this code online...
    • 23007
    Re: TA 4551ci F279 Error when coming out of sleep mode
    That's the next step. =^..^=
    • Doug James
      • Jan 2012
      • 935
      I ended up reseating the connectors and still got the code. Thinkin it would make a good parts machine... Appreciate you !!
      • sparkycivic
        • Apr 2017
        • 348
        I would look really closely at the low voltage pwb, that it's 5v rails are not sagging, rippling or missing during sleep/wakeup. There's should be at least one present to operate the panel and relays for starting the machine.
        Interestingly, I can' tfind "f27x" in several manuals I've tried...
