4820W color scanning issue
  • teklife256
    • Sep 2012
    • 164
    New style scanner. When color scanning to a pc the image has two vertical yellow bands on the right side. The yellowing corresponds to scan LEDs 4 and 5 (left to right). I cleaned all LEDs and swapped 4 and 5 with LEDs 1 and 2 respectively. After the LED swap all five individual LEDs gave off a yellow, pink, gray shading. A pic of the scans are below. I have double checked my connections. With all LEDs affected I’m leaning towards the Data Controller PCB having failed but I really don’t have much experience with this unit
    any ideas? Is there a calibration that may be helpful on the new style scanner? Before I go about replacing the Data Controller PCB in the scanner I’d like to exhaust any other options
    Thank you
