trasfert belt kyocera 2552-2553 light gray line and c2840 random
  • avio2
    • Jul 2010
    • 150
    first gray line:total paged printed : 200k , 150k bk 50k col
    last fw version
    cleaning motor tested ok
    checked waste box ass'y rear ok
    toner oem
    look attached example , printed in a4 the problem is the line I circled (not the bottom because I darkened the scan to show it)
    anyone have solved this without changing the belt?
    second C2840 :154000k 50000col
    last fw version
    toner oem
    in this i have grease gear cleaning and put a shim in the internal door that closes and covers the development-drum and belt groups so that it puts more pressure on the connector contact belt , not it work but not sure this is finally solved
    i asked this because I have more than one with these defects
    anyone have solverd this 2 issue?
  • Ropariva
    • Mar 2016
    • 676
    • avio2
      • Jul 2010
      • 150
      Re: trasfert belt kyocera 2552-2553 light gray line and c2840 random
      strange , image printed not have a problem , if blade rotate bad it should stain
      anyway thanks i will check with one i have here
        • 898
        I would take out fuser and look at discharge grid (spikes) really good and see if something in there . I have that issues with C2840 code
        • avio2
          • Jul 2010
          • 150
          strange IH it should not center with the belt but with the fuser
          • avio2
            • Jul 2010
            • 150
            for gray line i have disassembly cleaning , cleaning all and remove paper dust and toner, removed encrustations from the metal roller and replaced the brush roller with a used one and it seems to work
            very easy and fast
            at least they gave the single spare parts
            thanks @ropariva
              • 898
              Go to the search tab and enter 2840 , Ropariva has a service bulletin listing the 2553 and the 2840 code referencing about the grid .
              • Ropariva
                • Mar 2016
                • 676
                very easy and fast
                thanks @ropariva
                • avio2
                  • Jul 2010
                  • 150
                  [CITAZIONE=Ropariva;2151699]Haha. Hai provato a smontare una di queste cinghie di trasferimento[/QUOTE]
                  yes
                  already at other times, when the toner recovery and the discharge hopper get clogged but I had completely replaced the cleaning group with another one for recovery, only long and difficult and being alone to do assistance a few times the desire passes me
                  remove the front belt cover
                  remove the cleaning motor
                  Unscrew the front and rear screws that hold the cleaning assembly and rails where the springs are
                  rotate the entire cleaning unit and remove it
                  I hope I made it clear my English sucksazzo:
                  • avio2
                    • Jul 2010
                    • 150
                      • 898
                      • avio2
                        • Jul 2010
                        • 150
                        ok thanks
                        however the discharge grilles are clean and the fuser is good(very very strange)
