CS-1650 Engine Pwb
    • 23010
    CS-1650 Engine Pwb
    I've got one that was toasted by a brownout last week. Part number is 302DB93011. It's not the same as anything else (not CS-2050).
    Yeah I know it's old. And I had a power supply, so I can rule that out. Anybody? =^..^=
  • sparkycivic
    • Apr 2017
    • 348
    Re: CS-1650 Engine Pwb
    i don't have anything like that on hand, but could it have just opened a fuse on the board? current draw would go way up when the input voltage gets low, or did it blowed up other stuff?
      • 23010
      No fuses that I can see, and it fails the smell test. It smells like that frosted raisin bread that I put in the toaster, and started to burn. Hytec still can reference the number, but has a note: "no longer repairable" probably because they no longer have a CS1650 to test it in.
      Thank for your response. =^..^=
      • sparkycivic
        • Apr 2017
        • 348
        in my mind, i had pictured the lvpwb not engine. sorry.
        My sincerest condolances to the loss of your engine board.
          • 23010
          I was there for the brownout. AC voltages varied ... at first 53.5vac, then we got some surges, and it settled at 73.5vac
          I disconnected motor loads right away, like the refrigerator, sump pump, and furnace, but didn't think of the copier. I suspect the HVAC companies and the appliance repair people got quite a lot of work out of it. =^..^=
