White spots on copies and prints
  • Luis
    • Aug 2017
    • 14
    I'm having this issue on Olivetti D-color MF282
    Copies and prints come with those whites dot's just on black
    • 23008
    Re: White spots on copies and prints
    If it the Konica Minolta model that I think it is, bizhub C350, the developer is probably very depleted. =^..^=
    • allan
      RTFM!!
      • 5462
      Its a C284. Its leaking HV somewhere due to dev and unit probably shot.
      Replace the K devtank but test the drum by changing it to CMY position first. Need to change the chips around.
      Sure its only on black?
      Your on the wrong forum. This should be under Konica Minolta.
      How is Mozambique? Need machines?
      Whatever
