ECOSYS M6635cidn fax errors
  • kuby
    • Oct 2007
    • 1408
    We have a M6635cidn that keeps getting U01011, U01026 and U01056 errors when faxing. It is hooked up thru a Fax Modem and the internet.
    The setting are:
    Port 1:
    Communication Control 1:
    TX start speed: 14400 bps/V17
    RX start speed: 14400 bps
    TX echo: 300
    RX echo: 75
    Port 1:
    Communication Control 2:
    ECM TX: On
    ECM RX: On
    CED FREQ.: 2100
    Port 1:
    Communication Control 3:
    DIS 4BYTE: Off
    NUM. OF CNG(F/T): 2 Time
    Port 1:
    Communication Control 4:
    V.34: On
    V.34-3429Hz: On
    DIS 2RES: Once
    RTN CHECK: 15%
    Is there something I need to check, turn Off/On ? The Fax/modem has been replaced, printer firmware is up to date, line is clear.
  • copiertec
    • Jan 2016
    • 2210
    Re: ECOSYS M6635cidn fax errors
    You say the line is clear. Did the line provider physically check the line? Did this just start happening?
    • sparkycivic
      • Apr 2017
      • 348
      The fax modem is internal to the 6635cidn.
      I need to know more about the telephone line being used...
      • kuby
        • Oct 2007
        • 1408
        It is a Spectrum Fax/Modem connected to the internet and then to the machine and faxes with a digital signal.
        • scottybbb
          • Dec 2010
          • 126
          Try turning V34 off. You may need to reduce the TX and RX speeds lower than 14400bps.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1887
            Fax over VOIP.pdf
            Use this for the settings and make sure it's using a 2 wire line.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
