Black Streak
  • richs
    • Nov 2008
    • 260
    Black Streak
    I have a TA3252ci that is giving me a horizontal black streak on the first page of a black only print.It has a new black drum and I have tried a black dev ,transfer belt and fuser assembly.Any ideas ?
    • 23006
    Re: Black Streak
    If it's mostly the first page of a run, and it diminishes as it runs, I've seen this effect caused by the fuser. =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      Re: Black Streak
      That's the transfer belt. Can't believe you replaced it.
      • richs
        • Nov 2008
        • 260
        Re: Black Streak
        Only on first page.Yes I have tried a transfer belt...believe it or not.That is the first thing I tried.
        • nathicana
          • Aug 2008
          • 332
          Re: Black Streak
          Hi have a look at this
          first copy smudge.pdf
          • richs
            • Nov 2008
            • 260
            Re: Black Streak
            I replaced it with a new transfer belt and it seen to solve it.The belt i tried was from another machine in the same buidling that was working ok in the machine it was in but did not fixed the problem when I swapped it.This is why I always like new parts!
            • JR2ALTA
              • Feb 2010
              • 2033
              Re: Black Streak
              Then you owe me a like/thanks
