Disassembly DK-5195 drum units
  • campy
    • May 2012
    • 315
    Any instructions or videos on how to disassemble the drums for 307ci? I want to clean the drum blade and cleaning lamps due to streaks.
  • Luther
    • May 2006
    • 682
    Re: Disassembly DK-5195 drum units
    The blade comes out without removing the drum just remove the charge roller and you will see the 2 screws holding the blade in, the lamps should be cleaned right from the top of the drum unit, the blade is common to be cleaned for stripes.
    • campy
      • May 2012
      • 315
      Thanks. Is there anything tricky about removing the charge roller? I noticed a spring attached, does that come out with it?
      • Luther
        • May 2006
        • 682
        the spring stays on the drum unit, there is a metal clip that aligns with the spring when you put the charge roller back in
