Kyocera C7301 Toner Motor K error
  • StratManDan
    • Nov 2018
    • 96
    Has anyone seen this error code? I've tried a spare transfer belt, removed the toner supply drive, vacuumed it out, and made sure it isn't bound up with toner. Is it possible the Toner Supply Drive Unit needs to be replaced?
    Thank you
  • darry1322
    • Oct 2010
    • 817
    Re: Kyocera C7301 Toner Motor K error
    I've seen two things cause this. A fault in the toner supply unit (from the bottle to the dev unit) and a broken auger in the developer unit.
    • StratManDan
      • Nov 2018
      • 96
      So, darry1322, what did you do to fix it?
      • darry1322
        • Oct 2010
        • 817
        Replaced the toner supply unit or the developer depending on which was faulty.
        You can rotate the developer unit by hand and watch if the developer auger is turning.
          • 23009
          So what model was this? =^..^=
          • StratManDan
            • Nov 2018
            • 96
            CS 5002i
            • Massimo Italy
              • Feb 2021
              • 45
              sorry, but why open new treads on topics already discussed?
              I suggest using the search function before open new tread.
              • StratManDan
                • Nov 2018
                • 96
                To each his own, my friend.
