TA 3252ci Waste Toner Door Latch Grief...
  • Doug James
    • Jan 2012
    • 935
    [Misc] TA 3252ci Waste Toner Door Latch Grief...
    The Kyocera "02" Series copier seems like a good machine but what's up with the waste toner door latch ? I messed with one (door won't stay shut) for several hours today and could not find a good fix for it. I ordered some more latches. I am new to these machines. Does anyone have any suggestions for this other than using packing tape. Thanks so much for any comments !!!
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1874
    Re: TA 3252ci Waste Toner Door Latch Grief...
    If you have any parts machines, it's the same latch the bypass trays use on the ecosys machines. It's pretty easy to swap out.
    Also, the door was changed and a rib was added as the original iteration warped.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Doug James
      • Jan 2012
      • 935
      Thankyou so very much. Very appreciated !!!
      • sparkycivic
        • Apr 2017
        • 348
        is your door actually failing to remain closed, or is the machine telling you to close it? Early on, some of the 02 series has a sensor flag that would stick, and the symptom was constantly displaying "Waste container door open". very different fixes...
        • justanotherhack
          • Apr 2015
          • 74
          I had one, brand new machine, the waste toner bottle had a tendency to slowly walk out of the container until it pushed hard enough against the door to trip the door open message. Swapped the WTB itself, all good. Setup guys in our shop have seen this a few times.
