Check Toner Cartridge TaskAlfa 3510i
  • CiroB
    • Jun 2022
    • 3
    Good morning,
    I have a problem with a TaskAlfa 3510i.
    As soon as it starts it reports error to check the toner cartridge.
    I have replaced 3 toners (original) but it still reports this error.
    I have replaced as per the technical bulletin the cartridge sensor present in the belly of the MFP.
    I have replaced the engine board.
    I have replaced the main board.
    I have replaced the power supply board.
    All did not lead to the resolution of the problem.
    Any other suggestions?
    Thank you.
  • sparkycivic
    • Apr 2017
    • 348
    Re: Check Toner Cartridge TaskAlfa 3510i
    does the machine attempt to fill the developer at all before giving up or is the error immediate?
    Is the machine in a smoky or dusty environment?
    • CiroB
      • Jun 2022
      • 3
      The machine attempts to fill the developer after which the error appears.
      The machine is currently stopped in our service center.
      • dalewb74
        • Feb 2018
        • 1155
        firmware updated?
        • CiroB
          • Jun 2022
          • 3
          Firmware updated.
          • sparkycivic
            • Apr 2017
            • 348
            try a developer.
            also check that the developer is actually turning, same for the toner container by putting a mark on the drive gear.
            • Fabio-1
              • Mar 2022
              • 6
              This problem is generated by the sensor opt and the sw push behind the toner. You can try to clean them or chance directly.
              • marvin_PL
                • Jun 2012
                • 24
                Can I check this in u150?
