4052ci popping noise
  • kuby
    • Oct 2007
    • 1409
    There is a popping noise coming from the gear on the 302ND94013 PARTS BOX WASTE H ASSY SP gear. Is the box at fault or is the 02ND94224 PARTS WTB UNIT SP. Never had this before and I don't want to take something apart if I don't have to.
    Anyone had this problem before?
    • 23009
    Re: 4052ci popping noise
    There's most likely a blockage. You'll have to do some investigating. Usually you'll find a spun gear or a broken auger.
    Are you using generic toner? =^..^=
    • darry1322
      • Oct 2010
      • 817
      There's some info in this htread.
      kyocera 5053ci loud noise, buzzing or is it gear grinding.
      • kuby
        • Oct 2007
        • 1409
        Always used OEM toner.
        • KyoServiceManager
          • Oct 2017
          • 30
          Unfortunately, you will have to do some disassembly either way. I've had this happen for a few different reasons.
          1) The customer doesn't change the waste toner as they should and it back up the entire waste auger transport which in turn breaks the gear.
          2) The plastic portion of the waste toner box assembly ultimately snaps together as a top and bottom; I have had the top and bottom come "unsnapped" in the far back right corner looking in from the front side of the machine.
          3) I've had 2 cases early after these machines were released, where the toner would rocked up which would lock up the gears and cause them to break.
          In any of the above scenarios, you would still need to remove the Drive Assembly and at minimum vacuum the debris from the auger section. If it is a case of the toner being rocked up, I would just replace auger assembly.
          "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -Einstein
          • kuby
            • Oct 2007
            • 1409
            Yea waste toner bottle hopper is ok it is the waste toner auger assy and the transfer belt auger. Both locked up.
