DV8305
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    DV8305
    Just wondering if anyone would know of any differences between a DV8305k and a DV8305c, apart from the obivous colour difference?
    Can I use a cyan in the black area for instance?
  • rapo_tech
    • Feb 2019
    • 114
    Re: DV8305
    No u cant Even if you replace the electronics, how u supposed to replace all the toner?
    • fishleg
      • Mar 2009
      • 426
      Re: DV8305
      Run it till it changes, used to do it all the time on konicas. If its a new chip machine didn't care what colour dev it started with.
      Kyo on the other hand, I think without a new chip the tcr readings would go completely out. I may be wrong on the theory but every dev sensor is different so when machine detects a new dev the machine goes ooh OK this is my starting reading for this dev I'll store that.
      I have on the other hand put a slightly used dev in another machine with no ill effects had only done 20k copies in previous machine so maybe I got lucky. Kyo might take in the values just from a serial number change. I'm more inclined to say it would work than not work.
      • ATSBMCO
        Technical
        • Oct 2007
        • 70
        Re: DV8305
        Thanks for the replies.
        I should have been a bit more specific. I have a DV8305 with the usual mag roller skin fault, causing banding on one edge of the paper.
        I was looking at removing the mag roller from a cyan developer and putting it into the black developer.
        Does anyone know if they are the same roller?
        Thank you
        • PrintWhisperer
          • Feb 2018
          • 473
          Re: DV8305
          Thank you
          Would be the aptly named sleeve roller? The mag roller is the one in back.
          We can assume they are they same as they have the same circumference (the repetitive defect guage doesn't list a sep. size) but since they are not made to be taken apart no individual part numbers are listed. So no way to verify, and these types of units don't easily come apart.
          It never occurred to me to try, but it's close to the 'surface' so maybe. Whether it'll calibrate and work is another matter
          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
