P3260 Image Quality Problem IQP
  • Kyocera_fleet
    • Sep 2022
    • 20
    • 23010
    Re: P3260 Image Quality Problem IQP
    It looks like a dirty primary charge, maybe combined with poor drum cleaning. Have you cleaned the primary charge roller yet?
    Use minimal water or glass cleaner, and make sure that it's completely dry before re-installing the charge unit. =^..^=
    • Kyocera_fleet
      • Sep 2022
      • 20
      No i'didnt. I think it's best to customer get new DK-3190 / DK-3194 (there is 230v eu voltage) What differense between dk-3194 vs 3190. In manual 3194 is 240? What u think, wich one i have to order?
        • 23010
        How many prints on that drum unit?
        In the US it's a DK-3192 but I don't know about Finland. I don't have a manual for this particular model, but I would clean the primary charge roller first, and if that doesn't work, replace the primary charge roller. =^..^=
        • Kyocera_fleet
          • Sep 2022
          • 20
          Okay many thankses 4 responding. How about the cleaning systems like primary charge roller cleanin, some cases cleaning system fails and then comes a faults. If i want to be sure, is these cleaning systems in this dk-3190, roller comes with it.
          • Kyocera_fleet
            • Sep 2022
            • 20
            And only 6200 pages..... i know a drum is set up to 500,000 pages. Life counter are in this status page what i attach first post
            • Kyocera_fleet
              • Sep 2022
              • 20
              I thinking what kind systems is when it tranfering waste toner to box. Some cases this going to bloked somehow.
                • 23010
                Okay, many thanks for responding. How about the cleaning systems like primary charge roller cleanin, some cases cleaning system fails and then comes a faults. If i want to be sure, is these cleaning systems in this dk-3190, roller comes with it.
                There is no primary charge cleaning system on these models. The machine varies the primary charge to repel toner from clinging to the roller.
                There's probably nothing wrong with the drum or drum cleaning system at 6200 prints.
                I thinking what kind systems is when it transferring waste toner to box. Some cases this going to blocked somehow.
                It's possible, but unlikely. Start with cleaning the primary charge roller, letting it dry completely, them re-installing it. =^..^=
                • Kyocera_fleet
                  • Sep 2022
                  • 20
                  Okay, THANK u!. So can i make it better 4 high air pressure clean? Do it make it better. Very weird roller going dirty in these pages 6,2k
                    • 23010
                    High pressure air will not help. Use water or glass cleaner, wipe dry, then let it dry completely.
                    Is four repetitions of the same exact answer enough for you? =^..^=
                    • Kyocera_fleet
                      • Sep 2022
                      • 20
                      And if it not go to better i order MC-3100
                      • Kyocera_fleet
                        • Sep 2022
                        • 20
                        Yes sorry i clean it and watch what happens
