KM-2050 dirty on back of copies
  • cmpelser
    • Jan 2008
    • 173
    Fairly new installation... about 5000 copies.
    toner scatter on back of copies.
    I've noticed a bit of toner build up just below the drum and also a slight bit on the transfer roller.
    I wiped it away - it's a bit better but not compleatly gone.
    what it causing this?
  • cboucher
    • Aug 2025
    You could be having a cleaning unit issue or developing unit issue. Clean out both completely, run some copies and see what happens. You'll probably have to run U130 to put toner back into the developing unit depending on how well you cleaned it.
    • madhavanr
      • Mar 2009
      • 15
      i am also faced this problem twice.
      i replaced transfer unit, now its working ok.
      • jaime
        • 16
        sometimes cleaning the seal deforms and pulls toner to copy. I happen by a mishandling of the unit in question.
        • jummamaster
          • Mar 2009
          • 99
          Clean the transfer unit, make some copies, hope that solves the problem
          Ricoh Error Codes
          Canon Error 5100
          Canon Error B200
          j
          c
