km 3050 drum compatible with 3060 ? or vice versa?
  • faustf
    • Oct 2022
    • 2
    Hi guys the drum for km 3060 kyocera , is possible to use in kyocera km 3050 ?? the size is equal ?
    thanks
    • 22973
    Re: km 3050 drum compatible with 3060 ? or vice versa?
    It would help if you included a few more of the characters in the model number. Kyocera has manufactured a KM-3050 (FalconIII), KM-C3050ci (AlphardI Venus), ECOSYS P3050dn (6th Generation), KM-3060 (Stratos), ECOSYS P3060dn (6th Generation), ... maybe more.
    If you mean the ECOSYS P3050dn printer & the ECOSYS P3060dn printer, then yes ... they're the same.
    • faustf
      • Oct 2022
      • 2
      the drum is dark colored
      4 km 3050 https://external-content.duckduckgo....faa&ipo=images
      4 km 3060 https://external-content.duckduckgo....efa&ipo=images
        • 22973
        That's not going to work. Both drums are A-Si coating, but the FalconIII drum is 40mm diameter. The Stratos drum is 30mm diameter.
        Even if you separate the drum from the unit, it just won't fit. =^..^=
