Difference between PF-740 vs PF-740(B)
  • rustytechda
    • Sep 2021
    • 3
    What is the difference between PF-740 VS PF-740(B)? I know that the pf-740 is compatible with 3050ci, 5550ci, 6550ci, 7550ci, 7550ci, 3500i, 5500i, 6500, 8000i. The PF-740(B) is compatible with 7002i, 90002i, 7052ci. The reason why I'm asking is because i need - PARTS PWB FRONT DECK ASSY SP - PN = 303nf94060 for a PF-740(B). PF-740B is more stout than the pf-740?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1875
    Re: Difference between PF-740 vs PF-740(B)
    Generally they're identical, the (B) just means it's backwards compatible, so you couldn't use the PF-740 on the 7002i. Not sure if the board in question will work though.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
