Kyocera 4052 - Block of coloured lines on every page
  • FBS2021
    • Nov 2021
    • 13
    Hi All,
    When printing form one of our Kyocera 4052 machines, a block of colored lines appear on the page as shown below. Any ideas on how to get rid of the lines?
    I have replaced the yellow drum as the machine also had a C7904 error.
    Scan 082-compressed.pdf
  • Konicatech
    • Feb 2016
    • 131
    Re: Kyocera 4052 - Block of coloured lines on every page
    Hi
    Transfer belt is the issue.
    Check the cleaning assembly on the belt, you will likely need to change the belt though
    • CWP
      • Jun 2013
      • 168
      With 2 million pages on this machine isn't it about time for an upgrade??
        • 22997
        Also, make sure that the primary transfer waste spout is not obstructed. If the primary transfer waste auger is obstructed, then it's only a matter of time before the belt cleaning unit backs up again.
        The patches that you see on the copies are the color registration and toner density patches, that have not been properly cleaned off of the primary transfer belt. These patches are produced to calibrate the machine.
        • FBS2021
          • Nov 2021
          • 13
          The client has just signed a lease for replacement 5054 machines but unsure of delivery date.
          • FBS2021
            • Nov 2021
            • 13
            Originally posted by Konicatech
            Hi
            Thanks for this. I have cleanede the primary waste transfer unit and the colored blocks are now gone.
            • Konicatech
              • Feb 2016
              • 131
              Great, hopefully keep it going until the new machine arrives.
                • 22997
                Did you notice this part? =^..^=
                • FBS2021
                  • Nov 2021
                  • 13
                  Apologies I did but wasen't sure where that is located on the machine. It's not where the waste toner bottles are inserted is it?
                    • 22997
                    It runs the whole back of the machine, then to the bottle assembly. It's common on that model for the waste toner auger to back up, damaging augers, gears, and splitting open the two-piece housing. =^..^=
