Err_ssl_version_or_cipher_mismatch
  • kuby
    • Oct 2007
    • 1400
    Trying to log into the web interface on a used machine we purchased and get the message
    This site can't provide a secure connection
    X.X.X.X uses an unsupported protocol.
    ERR_SSL_VERSION_OR_CIPHER_MISMATCH
    Think the machine is to old to support TLS version, bummer.
  • copiertec
    • Jan 2016
    • 2205
    Re: Err_ssl_version_or_cipher_mismatch
    What browser are you using? Try Firefox, if using a Windows based browser. Turn on tls 1.2 of user side and server side in the security tab if possible.
    How to Fix ERR_SSL_VERSION_OR_CIPHER_MISMATCH
    • kuby
      • Oct 2007
      • 1400
      Thanks, already tried that too.
      Same message....
      • justanotherhack
        • Apr 2015
        • 74
        Hopefully you have a windows pc. Use Internet Explorer, or I.E. compatibility mode in Edge to access the webpage.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1880
          https://www.copytechnet.com/forums/k...ml#post2129510
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • rapo_tech
            • Feb 2019
            • 114
            Easiest solution is to use older Firefox: PortableApps.com - Browse /Mozilla Firefox, Portable Ed. at SourceForge.net
            Get 3-4 years old firefox and you can access web interf.
            • kuby
              • Oct 2007
              • 1400
              Got into the printer web interface. It was a setting the dealer had turned on. And they changed the Admin user name and password. It the a way to clear that back to the default?
              • yakyitz
                • 245
                If you can login to the machine using the numerical login, go to login authentication/job accounting and you can change the admin password.
