Kyocera M3655idn slit glass needs cleaned message
  • copykat93
    • Oct 2021
    • 281
    Hi guys, got this annoying message on an M3655idn that the customer asked me if there was a way to turn off the message to clean the slit glass... can this be done? I looked in the menu of the machine, but didn't see an obvious setting to turn it off.. I did see an option to turn off line sensing, but didn't want to do anything till I checked here first. Any suggestions?? Thanks
  • progoffice
    • Nov 2008
    • 336
    Re: Kyocera M3655idn slit glass needs cleaned message
    Maintenance mode 326
    U326 Set Black Line Clean Display
    Sets whether to display the cleaning guidance when detecting the black line.
    • copykat93
      • Oct 2021
      • 281
      Thank you very much, appreciate your quick response!
