Kyocera 7052ci jam that won't clear. Exit Feed switch?
    • 30214
    #16
    Re: Kyocera 7052ci jam that won't clear. Exit Feed switch?
    OMG
    This is a perfect example of an untrained unauthorized service technician
      • 16391
      #17
      OMG
      No worries, little buddy. You keep doing things your way. Just know that I can locate every PJ sensor before you can open your service manual. No response necessary.
      Unless you know where every sensor is by memory? Don't tell that lie, little buddy.
        • 30214
        #18
        Apparently Not
        Dude you can't even load a print driver.
        If you can't find a paper feed sensor you need to find another job little Buddy
          • 16391
          #19
          The sign of every good tech is to put on you ignore. Back you go, little buddy.
            • 30214
            #20
            The sign for every good tech is to put on you ignore. Back you go, little buddy.
            I know you read every post
            Maybe one day you can fix something
            Back to your YouTube training
              • 30214
              #21
              Authorized trained techs don't have to use the service manual to locate switch's. Only the untrained rookies
              OMG
              Your should be learning the jam codes and trouble codes but what do I know? hahajajha
                • 16391
                #22
                OMG
                I sincerely hope that no one buys into your ignorance. This thread was started (not by me) because of the confusing nature of the Kyocera Service manual when trying to trace down the different sensors. Specifically using sim. U031.
                GTFOH. With advice like that, I wouldn't let you work on my toaster. OMG.
                  • 30214
                  #23
                  You don't even own a toaster.
                  PS Kyocera service manuals are the easiest to understand. Rookie keep reading them ��
                    • 16391
                    #24
                    By the way, thanks for the person that started this thread and thanks to blackcat for talking about the different names for the sensors/signals in the differet parts of the service and parts manual. It made me do my homework and I'm better for it.
                      • 30214
                      #25
                      OMG get some training
                      STOP POSTING EVERYTIME YOU LEARN SOMETHING
                        • 16391
                        #26
                        11 of 14 coming up, little buddy. Training. Always training.
                          • 30214
                          #27
                          Thank God No Finisher
                          OH BOY THE exit sensors
                          OMG
                            • 16391
                            #28
                            Thank God the exit sensors
                            OMG
                            There are 2 exit sensors. Which one are you referring to?
                            1. Exit paper - located directly after the fuser.
                            2. Exit Feed - located in the switchback unit.
                            • tsbservice
                              Field tech
                              • 8013
                              #29
                              Interesting thread. I have no problems reading Toshiba and KonMin manuals but I'm surprised to hear Kyo has so many misleading and confusing parts in their manuals. For sure the copier god(aka blackcat) advise will work but imho that disarrangement is a shame for such a good brand.
                                • 30214
                                #30
                                Kyocera is one the easiest brands the manuals are very good. The problem is don't over think Kyocera.
                                Coming from Canon or Konica or Xerox the names of the same components are different.
