CS 5054ci / DF-7140 / PH-7A Only showing 2 hole punch option.
  • copytech_32716
    • Nov 2022
    • 19
    I set up a CS 5054ci with a DF-7140 and a PH-7A.
    But when I boot it up it only shows 2 hole punching available.
    How do I get 3 hole punching?
  • CoreyAbels
    • Dec 2014
    • 91
    Re: CS 5054ci / DF-7140 / PH-7A Only showing 2 hole punch option.
    If memory serves, you have to go into Service Mode U234 and set the Punch Destination.
    • copytech_32716
      • Nov 2022
      • 19
      Thank you. That worked.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1880
        We've had quite a few come in that were set to Japan as the country code.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • CoreyAbels
          • Dec 2014
          • 91
          We've had a few weird "out of the box" issues, this punch destination setting being one, and most recently one side of the tandem trays was set to A4 and the other to Letter. Add that to the busted accessories shipped via UPS/Fed Ex Ground rather than freight with no visible damage to the boxes and I'd say there are some QC/SOP issues going on lately.
          Sent from my Pixel 7 using Tapatalk
          • tmaged
            • Oct 2008
            • 1880
            Desk units sent UPS almost always come in with some damage. They're too heavy to ship that method.
            We had a 4004i come in LTL, that had NO visible damage to the box. The machine was trashed inside. The scanner was all crooked under the glass and every side had cover and/or frame damage.
            Hope that helps !
            -Tony
            www.dtios.com
            • Tonerkiller
              • Oct 2012
              • 668
              The manual staple for the 4000 sheet finisher needs to be set to letter also. It comes defaulted to A4
