306ci/307ci ticking noise
  • BR549
    • 111
    [Misc] 306ci/307ci ticking noise
    I have 3 of these in my shop doing this. 2 306ci's and 1 307ci. It's coming from the transfer belt drive. I can remove the transfer belt and turn the belt drive gear in the machine and hear the noise. I know I could tear it apart and find the noise, but that's a heck of a job. Looks like the motor would be removed from the rear ,but the rest of the drive assy would need to be accessed from the front since it is at the rear of the cavity. Any help is appreciated. Thanks.
  • progoffice
    • Nov 2008
    • 336
    Re: 306ci/307ci ticking noise
    We've had a few of these too. Not sure if it's the same noise your describing, but for us the plastic housing was cracked around the gear that drives the transfer belt causing gear skip. I don't think there's even a part you can order to fix it, and if you did try to replace it you'd have to tear most of the machine apart to do so. We've had success just using super or Gorilla glue to give it enough strength to prevent the noise.
    • JR2ALTA
      • Feb 2010
      • 2033
      If it's that brief sound of gears skipping at warm-up then the above answer is 100% correct. And I'll add. a tricky little bugger to diagnose.
      • BR549
        • 111
        It's not a brief sound. It makes the sound the whole time it's printing. I've got the transfer motor out along with the gears that are mounted to it. The noise is not there. I haven't seen a crack yet. Been looking for one.
        • sparkycivic
          • Apr 2017
          • 348
          I had one that make noise at startup of the printing process. using the super-slow-mo feature of my phone camera, I bypassed the side door interlock to watch the transfer belt drive, and saw that the drive motor plate was bending under the strain and having very little structural support for forces acting in that particular direction. It was quite high-mileage by that point and I already put a new transfer belt and a lot of other service parts to keep it alive. I added a screw to it as close as I could get to the limit of the unsupported area of the plate, which helped somewhat, but was ultimately returned pretty soon thereafter, so it became a lost-cause and the machine was "retired" out back of the customer's premesis.
          • BR549
            • 111
            Well it was the toner supply unit. After calling Kyocera tech support twice about this and they tell me they don't know anything about it, my coworker found a service bulletin on it, 2R4-0030 (I155). 16 page bulletin! Dated 10/18/2018. Says 3-4 hour job! Not sure why toner supply turns with transfer belt but it does. Explains why I also heard the noise when I ran U132, forcible toner supply. Another symptom is toner empty cannot be resolved, Because the toner, any color, is clogged up in the toner supply unit.
            • Copier Mechanic
              • Mar 2023
              • 89
              Mostly likely caused from using cheap toner. They clump up inside.
              • BR549
                • 111
