Forward Faxes in memory to email or other machine
  • thinkink
    • Apr 2016
    • 63
    We have a customer that does a lot of faxes on a Kyocera M3550. The registration switch broke inside and is throwing a paper jam. They customer didn't realize this till there are about 100 faxes in jobs pending. It would be a very time consuming job to change this switch. We have other used M3550 on hand. Does someone know if these faxes, already in memory as paused print jobs, can be forwarded to an email or fax number.
    Or where are these stored on the printer. Would it be possible to swap a board on another machine to retrieve them? The customer is pretty desperate for them. I think this will push them to push measures in place to insure they are forwarded to email as well in the future.
    • 23010
    Re: Forward Faxes in memory to email or other machine
    If fax forwarding had been enabled BEFORE the breakdown, you would already be set. Now that they are in memory, no. Printing is the only way out.
    Just out of curiosity, what if you switch the fax board from the broken machine into your working 3550? It might work. I've noticed that on Kyoceras, removing the fax option makes the fax Rx's vanish. Reinstalling the fax card makes the fax Rx's reappear. =^..^=
    • sparkycivic
      • Apr 2017
      • 348
      might need to just glue something to what remains of the switch just to get those jobs out of the device. a paperclip, trimmed after the glue sets could work if you can reach enough to work in there...
      • thinkink
        • Apr 2016
        • 63
        THANK YOU so much! we were able to get our old jobs out by miving the fax board to another machine. You have an amazing amount of knowledge!
        • subaro
          • Oct 2010
          • 1274
          fgf
            • 23010
            Originally posted by thinkink
            THANK YOU so much! we were able to get our old jobs out by moving the fax board to another machine. You have an amazing amount of knowledge!
            Congratulations on your success. =^..^=
