Will 4500i aftermarket PCR's work as well in the 4551ci,just use same roller in both?
  • CCS
    • 266
    We go through alot of the PCR's sourced aftermarket, will the B&W 3500i/4500i roller work in all: 4501i/4550ci/4551ci/5551ci without issue?
  • Samanator
    • Sep 2017
    • 579
    Re: Will 4500i aftermarket PCR's work as well in the 4551ci,just use same roller in b
    Yeah, it will fit.
    Depending on where you get your PCRs, the failure rate will be about the same.
    Sometimes its not the rollers fault. I have clients using paper so cheap that causes any PCR to turn white in no time.
