8003i/9003i Wire Harness Jig
  • CoreyAbels
    • Dec 2014
    • 92
    Gentleman,
    Does anyone here know if Kyocera still produces wire harness jigs for the products that still use a pull-out style right door? They use to have a jig for the older 51ci machines and it would be nice if they produced them for the 8003i/9003i machines as well. For those that don't know, the harness jig allowed you to run/test the machine with the right door open. I've asked our tech rep and he's looking into it, but I figured I'd throw it out to you guys as well.
  • taskalfaman
    • Nov 2009
    • 137
    Re: 8003i/9003i Wire Harness Jig
    Originally posted by CoreyAbels
    Gentleman,
    I think you can use the one of TA-xx51ci series
    BE
    • dalewb74
      • Feb 2018
      • 1155
      so you are just trying to trick the copier into thinking the door is closed? no jig needed, just use a piece of paper. slide it into where the door closes on the sensor. have done it on kyoceras and other brands as well. have also used a flathead screw driver, piece of cardstock paper, and etc.. give it a try.
