Kyocera M3145 weird click after installing MK3262
  • copykat93
    • Oct 2021
    • 281
    Hi guys, Kyocera M3145idn, brought in the shop because the fuser needed replaced, drum needed replaced, so I went ahead & did the 300K kit & after installing the fuser assy, (only on initial turn on) it will click when it is running the fuser pressure drive. After it makes 2 clicks, it then completes the drive for pressure & all is fine. I thought maybe I installed crooked or didn't install correctly, but I reinstalled it with the drive lobes down, & it will click 2 times, then finish the warm-up & after that, the machine is super quiet.. made over 100 pages & no noises at all. If I turn it off or unplug it, I get the same 2 clicks when powering on and then its fine. It didn't do any clicking prior to me doing the fuser. Any suggestions??
  • ntbann
    • Jan 2012
    • 631
    Re: Kyocera M3145 weird click after installing MK3262
    Does it click with the old fuser in it? If not then the new fuser may have a clamp defect.
    • copykat93
      • Oct 2021
      • 281
      Yeah... I reinstalled the old fuser & sure enough, same click... didn't notice it before, but yep, It does the same click as the new one... so I put the new fuser back in & it only clicks 1 time on start up.. I did it several times at power up it clicks 1 time and then its fine... I'm now wondering if the click is more of a re-setting ratchet, because the pressure is already at max, then turn it off, then back on, 1 click like a ratchet resetting to then re-apply pressure to start a new power up procedure....Hmmm
