Copystar Bulletin #98, Setting Up Fax In A Voice Over IP Environment
  • monarke4
    • Oct 2018
    • 185
    Copystar Bulletin #98 (02/18/20), Setting Up Fax In A Voice Over IP Environment...
    Does anyone have this bulletin which they can share?
    Thank You
    • 23010
    Re: Copystar Bulletin #98, Setting Up Fax In A Voice Over IP Environment
    Try this one:
    • monarke4
      • Oct 2018
      • 185
      Try this one:
      Thank You...
      Seems Kyocera and the Copystar brand re-used Bulletin numbers?
      I suppose for the amateur like myself this can be a bit confuzzling. However those well seasoned techs and supers, have learned to roll with the punches.
      From #99's bulletin data, there is one unknown which I need to confirm first (G.711 audio codec).
      The other items will rely on analysis-adjustments after some trial and error.
        • 30421
        Originally posted by monarke4
        Thank You...
        turn off the v34 modem than if you if get errors
        drop the modem speed down to 9600 never had to make other adjustments
