Kyocera Taskalfa 406ci drop outs
  • Jaws
    • Oct 2007
    • 236
    Have a taskalfa 406ci that had dents on charge roller causing dots on prints. Changed the charge roller and the dots went away. Now when I went to calibrate I see a bunch of drop outs. I guess I should have changed the whole drum. Or is the developer unit causing these drop outs??? See photos.
  • copiertec
    • Jan 2016
    • 2211
    Re: Kyocera Taskalfa 406ci drop outs
    I see multiple color issues. What charge roller did you replace? It looks like there is more than one that you have an issue with. did you preform a laser cleaning and calibration?
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1888
      I'd run a LSU cleaning before I started just replacing things.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Jaws
        • Oct 2007
        • 236
        Is there a U number to perform this cleaning or do I manually clean the polygon mirror?
        • Jaws
          • Oct 2007
          • 236
          I replaced all four charge rollers. Is there a U number to run the cleaning or do I hand clean the polygon mirror?
          • Jaws
            • Oct 2007
            • 236
            I found the cleaning code U474 thanks
            • tmaged
              • Oct 2008
              • 1888
              You can do it through the system menu>adjustments
              Hope that helps !
              -Tony
              www.dtios.com
              • copiertec
                • Jan 2016
                • 2211
                As Tony has mentioned it's in system menu>adjustments, also you will find your quick calibration there as well.
                  • 900
                  Even if the LSU cleaning does not solve it i would physically look at them . I had one where strands of thin hair like material was not on the glass but stuck on the opening frame causing a issue like that
