Task alfa 2551ci jam 0511
  • newdente.gianluca
    • Feb 2016
    • 60
    [Jamming] Task alfa 2551ci jam 0511
    Hello, I have this machine that causes jamming problems jam 0511, I find a sheet stuck in the fixing unit and a sheet immediately after the paper pick-up (the paper pick-up takes place), if I take the paper pick-up and the a4 drawer and pass it into the a3 compartment the machine works, if I use the bypass the machine works so the problem is in a4 the upper drawer, has anyone already solved this problem?Thank you.
  • eddie110171
    • May 2012
    • 133
    Re: Task alfa 2551ci jam 0511
    How many pages on the unit? How many times has it had the jam? Have you replaced the feed rollers already?
    • newdente.gianluca
      • Feb 2016
      • 60
      life count 165895, pick up rollers changed but problem persist, total jam 0511=147
      • eddie110171
        • May 2012
        • 133
        Try changing the paper from letter to letter R. If this works to me it usually indicates a timing issue. For some reason Letter R seems to work better with timing issues. If that helps with the jams, I would look at drive clutches and the sensor for registration.
