C0060 error code on KM 3212i
  • konicatoshiba
    • Jan 2023
    • 33
    I have a kyocera 3212i with error c0060, I have replaced the engine, mainboard, still no error, please tell me how to fix it. thanks
  • Step
    Senior Technician
    • Sep 2015
    • 42
    Re: C0060 error code on KM 3212i
    I will suggest you then check your connections and cabling for any defect.
    And Clean the engine PWB connector (YC17)
    and reconnect it.
    Upgrade the firmware to the latest version
    Especially if you replace boards make sure to do Firmware so that all the boards run on same version.
    Sent from my SM-A736B using Tapatalk
    • KYO_OEM
      • Aug 2011
      • 721
      what would done before C0060 appeared?
      On b/w systems you are able to run U935 for 3 times only.
      Each time period takes 30 days.
      That means after 90 days, U935 will not work anymore.
      maybe one incompatible pwb or wrong FW on SSD card at the moment.
      in past i have had 1 tech who installed new SSD and running wrong FW upgrade after mounting new SSD card.
      It was Iris/ low color system and he installed FW from 3212i, after reboot he got C0060!!
      U019, CTRL FW xxxx.2V6 instead of needed xxxx.2ND was visible.
      But this is possible in case of installation from new SSD card only.
      systems won`t access wrong FW later.It`s not possible to install wrong ctrl fw anymore.
      If 1 time xxxx.2ND installed, system will accept newer xxxx.2ND only, you are not able to install ctrl xxxx.2V6
