Errore f25c su kyocera m2135
  • CIRO
    • Apr 2020
    • 33
    Good evening,
    For this code I first reset everything with (021) after which I put the latest fimware, the result when the multifunction is not on the network does not show the code described above, while as soon as I put the network cable a few minutes the code f25c appears .
    Kindly can someone give me some suggestion.thanks
  • kuby
    • Oct 2007
    • 1409
    Re: Errore f25c su kyocera m2135
    Could be that someone sent a document in a format it does not recognize. Try deleting the print que and and the documents from the printer. F codes can be brain testing.
    • CIRO
      • Apr 2020
      • 33
      The code also appears when the printer is at rest, I check that there are no prints in the queue
      • kuby
        • Oct 2007
        • 1409
        Are you the only one that prints to this machine? If not you may have to find out who was trying to print and what they were trying to print and delete from their que. Worth a shot.
        Also:
        F25X Abnormality detecting in a network management
        department
        (1) Carry out U021 Main backup initialization and perform an operation
        check.
        (2) Exchange a Main/Engine PWB and perform an operation check.
        ALSO reseat any memory that might be installed.
        (3) Get USBLOG and packet capture and contact service headquarters.
        * It may occur according to a visitor's
        network environment.
        Ethernet Connector
        [Main unit<=>Outside network]
        Ethernet connector
        Ethernet Connector
        • CIRO
          • Apr 2020
          • 33
          are you the only one that prints to this machine? If not you may have to find out who was trying to print and what they were trying to print and delete from their que. Worth a shot.
          yes of course it's the only one that prints
            • 16416
            On other models you go into the Web Interface and go to Security Setting and Error Setting and turn on Auto Error Clear. (may need to input the code, have not viewed this model yet).
            • CIRO
              • Apr 2020
              • 33
              THANK YOU, I'LL TRY
