Error code 3101 scan to Email FS-6530
  • Zezo54
    • Sep 2023
    • 2
    I have a problem when scanning to email, an error 3101 appears.
    The method used to set up SMTP is direct sending without authentication. Use MX record for Office 365 because the Kyocera FS 6530 does not support TLS.
    Port: 25
    When running a connection test, OK.
    But when I scan from the machine, error 3101 appears
    I tried to replace the host name with the IP.
    I checked the mxtoolbox website,
    also upgrade the firmware
    But the problem persists.
    Does anyone have an idea to solve this problem?
  • tmaged
    Owner/Service Manager
    • 1897
    Re: Error code 3101 scan to Email FS-6530
    3101 means the SMTP server responded with an error. I've never set it up using port 25, unauthenticated on Office365, but usually when doing this method, sending inside your domain is the only possibility.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Zezo54
      • Sep 2023
      • 2
      I've done this before without authentication and using port 25 and it worked on the same FS6530 machine
      by Office 365.
