Kyocera M2735 makes a cracking sound as the paper passes through fusing unit
  • i-have-fax-problems
    • Mar 2020
    • 106
    I guess there is something wrong with the fuser.
    Isn't there a general problem with the fusing unit
    of this series?
    What can I do?
    Thank you
  • DRichard
    • May 2008
    • 482
    Re: Kyocera M2735 makes a cracking sound as the paper passes through fusing unit
    of this series?
    What can I do?
    Thank you
    Replace the fusing unit.
    "Enjoy every sandwich."
    -- Warren Zevon
    • DRichard
      • May 2008
      • 482
      of this series?
      What can I do?
      Thank you
      Replace the fusing unit. FK-1150
      -- Warren Zevon
      • GIUBOSS
        • 1436
        I would also check the coupling gear
        • gimikbg
          • Jul 2021
          • 6
          If you have 30-60 minutes, you dont need to replace the fuser unit!
          It is very easy repair, and will cost you nothing.
          Kyocera P2235dn, M2040dn paper jam. Fuser repair. - YouTube
          I have maked this to more than 50's FK-1150.
          Works like a charm!
          https://www.youtube.com/@GIMIKBG
