Kyocera P3055dn Check cassette 1
  • Jinn
    • May 2023
    • 134
    Hi,
    Printer is showing check cassette 1 error upon closing. If Tray 1 remain open error will not show. As the tray is closed it shows check cassette error. The tray lift up motor is not working or any gear worn out? Printer restarts with normal sound. No noise.
    Any advice to fix this issue?
  • tee
    • Aug 2014
    • 79
    Re: Kyocera P3055dn Check cassette 1
    I check lift motor by pressing the cassette size switches on the bottom right side
    when tray is removed, then I lift the feed roller unit up to check the upper limit sensor.
    It should stop the lift motor at that time. I run the lift gear all the way around to
    insure the lift motor assembly isn't damaged.
