Kyocera (Utax) 3206ci Automatically open copy function?
  • Kazzy
    • May 2023
    • 64
    Hi all, recently was called to a Utax 3206ci, customer states they got a new, slightly used machine and it will not automatically open the copy function when you place a document on the platter.
    I must say we deal majority in Konica's and I honestly have no clue if ti's ment to open that function or not. I know for a fact Konica's do it but that's due to a different UI.
    Could someone reimburse me here and tell me if those 3206ci models are ment to automatically open the copy function once you put a document on the platter?
    Thanks.
  • KYO_OEM
    • Aug 2011
    • 714
    Re: Kyocera (Utax) 3206ci Automatically open copy function?
    UTAX 3206ci is common to Taskalfa3252ci
    needed feature not available on Kyocera systems.
    But you can set default screen by using this way:
    [System Menu/Counter] key > [Common Settings] > [Default Screen]
    Select the screen appearing right after start-up (default screen).
    Value: Home, Copy, Send, FAX*1, Status, Custom Box, Job Box,
    Removable Memory, FAX Box*1, Program, Home (Accessibility), Accessibility
    Copy, Accessibility Send, Accessibility FAX*1, Internet Browser*2, Application
    Name*3
    *1 Displayed only when the optional FAX Kit is installed
    *2 Configure necessary settings for Internet Browser.
    *3 The running application will be displayed.
