kyocera FSC 8525
  • 1stcavvet
    • Apr 2015
    • 231
    [Misc] kyocera FSC 8525
    I have a problem with the black developer unit not turning. I see in the manual there is a seprate motor for black. I can't find any info on the disassembly and removal. is it part of the main drive? is it a big deal to replace and is there a part# the colors work fine ---no black print on the status page I marked the mag roller--- it's not turning
    • 22966
    Re: kyocera FSC 8525
    I have never been into the main drive on a Hanabi, but if it's like most other Kyoceras, it's a major operation. Both VoyagerE's and Saturn were known for stripping gears in the main drive pack at 1M prints. I wouldn't be a bit surprised if it were something like that.
    My recommendation is to do this in the shop if you can. =^..^=
    • 1stcavvet
      • Apr 2015
      • 231
      Do you know what actually drives the black developer? When look at the motor section in the parts manual it shows one motor called CYM drive and the other is called K drive. but in the service manual, it doesn't give you any removal/ disassembly instructions, for either drive.
        • 22966
        I haven't had to do it, but found this procedure in the KM-255C manual (also a Hanabi). =^..^=
        • 1stcavvet
          • Apr 2015
          • 231
          thanx alot, that doesn't look so very hard. I think I'll take a look and see what's making the black to not turn thanx again
            • 22966
            Let us know how it goes. =^..^=
            • brancas
              • Jul 2009
              • 78
              Had that same issue on A FSC 8520. After changing the black dv ,DR 895C drive unit(which also drives the black dv unit) with no change I installed a Engine board and it worked.
