KM 4035
  • tcypy1961
    • 773
    KM 4035
    I am working on a Km 4035 in shop preparing to take out. I first had to swap-out the adf receptacle on copier then I swapped out the fuser unit with one from a KM 2530. A C-6000 came up on the 4035 however the heater lamps do come on for about 30-45 secs. before coding out. I swapped back fuser units and still get the code. Is there a reset I'm unaware of or is there something I could've done from the described work to have caused this problem???
    Thanks!!!
  • Sayen's
    • 20
    Sim 163 to reset fuser and don't believe the fusers on these models are compatable
    • Dustin(WOP)
      • 223
      try a u906 reset this usually solves some problems for me
      • tcypy1961
        • 773
        Tried both reset procedures with both fuser units cleaned the connector YC 10 plus additional connectors to the fuser on backside of copier; still no luck. Any other thoughts???
        Thanks!!!
        • Berny
          HP toolbox
          • 33
          C6000 : Broken fixing heater wire U have to reset the error code by using simulation 163
          Fuser Km4035 have 2 thermistors KM2530 got only one then they are NOT compatible
          Possibles causes
          Poor contact in the fixing unit thermistor 1 or 2 connector terminals.
          Fixing unit thermistor 1 or 2 installed incorrectly.
          Fixing unit thermostat triggered. (check continuity)
          Fixing unit heater M or S installed incorrectly.
          Broken fixing unit heater M or S wire.
          You can also check the 5 fuses on the Power supply board
          • tcypy1961
            • 773
            I do see the heater lamps come on and on occassion the copier will very briefly say ready to copy then the C-6000 code comes up. Any other thoughts???
            Thanks!!!
